dinesh2931
Newbie level 5
I have made a Bluetooth controlled car using arduino board. which is controlled using the android mobile. I used chassis, Bluetooth module HC-05,Motor driver & a app installed in the mobile to control the moment of car using Bluetooth serial interface.I used 12v battery for that.
The question is: The battery is discharging very fast, If I use for a long time.Again I have to charge the battery.
So, I thought an idea that instead of using battery and charging it often.I can use the Solar panels and save the charge in battery and then use it.
Is this is possible???And what should I do for that??
