Block up converter Ka band
akhilpaulv
Full Member level 2
Thrissur, India
Hi ,
in Ku band block up converter, The input frequency is 950 MHz to 1950 MHz . My question is the first harmonics of 950 MHz is 950*2= 1900 MHz. Which is in band of the system frequency . For Up converting if i fed the signal to the amplifier then the 1st harmonics will exists, i cannot filter out the first harmonics because it is in band of the system . Then for up covering i fed the signal to the mixer, output of the will contain the signal products such as L+IF , l+2*IF , the both signals are also in band of the system . Still there is a lot of SSPA modules are available in the frequency ? Can somebody explain how to remove all these spuries in this system??
-AK
Yes.
Why are you upconverting the entire 950 - 1950 MHz input band with a single LO frequency if you are so concerned about 2nd harmonics of the input?
The best you can do is use super balance mixer, with a very large LO power level, and have the input power level as low as you can tolerate for noise reasons. That way the 2nd harmonic in the mixing process will be minimized.
-67 dbc 2xIF with this mixer, for instance:
https://www.markimicrowave.com/Assets/DataSheets/MT3-0113HCQG.pdf?v=100518
