Blinking LED with Timer 1 of PIC16F877A
jean12
Advanced Member level 2
Hello,I am trying to use the timer 1 in Timer mode for timing a determined time for blinking a LED ,but I am not coming out with this,could anyone help me to sort this out?
I am uisng MicroC
the the code below I was trying to use:
PHP:
//#include <16f877a.h>
int count=0;
void main(void)
  T1CON=0x01;
  TRISC.F7=0X00;
  TRISD.F1=0X00;
  while(1)
  while(TMR1IF==1) ;
    PIR1.TMR1IF=0;
      count++;
      if(count==15)
      count=0;
      PORTC.F7=1;
       delay_ms(1000);
       PORTC.F7=0;
Please help,thank you!!
You are in a wrong category, should be in Microcontrollers
  while(TMR1IF==1) [SIZE=4][COLOR="#FF0000"];[/COLOR][/SIZE]
    PIR1.TMR1IF=0;
I have not pay attention in the logic of your code at all, but as you can see there is a while() and a block following that are not connected. Was that your intension?
Do try some corrections.
I do not like MicroC and so I am not using it. The code bellow may need some variable names corrected to MicroC syntax:
void main(void)
  int count=0;
  T1CON=1;
  TRISC.F7=0X00;
  TRISD.F1=0X00;
  while(1)
          //wait till tmr1 overflows
          while(PIR1.TMR1IF==0) ;
          //tmr1 overflows
          PIR1.TMR1IF=0;
          count++;
          if(count==15)
                count=0;
                PORTC.F7=!PORTC.F7;
if you have an 4MHz oscillator, the led should stay on for about a second and off for the same time. This will last till powered off.
Hello,Xenos;your codes are very interesting and running as you stated,what if I want a LED to be on a different time to off time of the same.
Assume ON time=1s
OFF Time=5s
I would like to use also for loop for helping me for example to implement the following:
1.OFF TIME=5s
2.OFF TIME=5s
3.OFF TIME=5S
4.ON TIME=2S
5.OFF TIME=5s
Please help,
1.OFF TIME=5s
2.OFF TIME=5s
3.OFF TIME=5S
4.ON TIME=2S
5.OFF TIME=5s
Simplified this says: 20s OFF / 2s ON
Klaus
no no,I was meaning
1.OFF TIME=5s
2.ON TIME=2s
3.OFF TIME=5s
4.ON TIME=2s
5.OFF TIME=3s
6.ON TIME=2s
7.OFF TIME=5s
8.ON TIME=2s
9.OFF TIME=5s
Thank you please help!!
Should it now 5s OFF / 2s ON in a loop,
Or do you really want the 3s of your line 5?
If your table starts with OFF, then it should end with ON.
Klaus
that`s it use microc for showing it.
Thx
