[SOLVED] Blinking LED simple program
sahu
Advanced Member level 2
Uttar pradesh (INDIA)
Dear All
Plz guied me I need a simple program for LED1 to LED8.
task_1
when S1 unpressed ;
{LED=11111110;}
(HOLD IT for 2sec)
{LED=11111101;}
(HOLD IT for 2sec)
{LED=11111011;}
(HOLD IT for 2sec)
{LED=11110111;}
(HOLD IT for 2sec)
{LED=11101111;}
(HOLD IT for 2sec)
Repeat this function every time till S1 unpressed .
task_2
but when S1 pressed for 1time within 1sec
{LED=11111110;}
(HOLD IT for 20sec)
& ofter 20 sec exit form task_2 & Repeat this function task_1
but when S1 pressed for 2time within 1sec
{LED=11111101;}
(HOLD IT for 20sec)
but when S1 pressed for 3time within 1sec
{LED=11111011;}
(HOLD IT for 20sec)
but when S1 pressed for 4time within 1sec
{LED=11101111;}
(HOLD IT for 20sec)
"if / else"solve this issue and update dummy register every switch pressed and copy the dummy valve to LED
Which MCU is using
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
if(sw_pressed)
   count++;
  switch(count)
  {   case 1:   LED=11111110;
                  delay(20sec);
      break ;
      case 2:   LED=11111101;
                  delay(20sec);
      break ;
      case 3:   LED=11111011;
                  delay(20sec);
      break ;
     case 4:   LED=11110111;
                  delay(20sec);
                  count=0;
      break ;
else
     {LED=11111110;}
delay(2sec);
{LED=11111101;}
delay(2sec);
{LED=11111011;}
delay(2sec);
{LED=11110111;}
delay(2sec);
{LED=11101111;}
delay(2sec);
Reactions: sahu
    sahu
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
if(sw_pressed)
   count++;
  switch(count)
                  delay(20sec);
      break ;
                  delay(20sec);
      break ;
                  delay(20sec);
      break ;
                  delay(20sec);
                  count=0;
      break ;
else
     {LED=11111110;}
delay(2sec);
{LED=11111101;}
delay(2sec);
{LED=11111011;}
delay(2sec);
{LED=11110111;}
delay(2sec);
{LED=11101111;}
delay(2sec);
thank u boooos
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
if(sw_pressed)
   count++;
  switch(count)
                  delay(20sec);
      break ;
                  delay(20sec);
      break ;
                  delay(20sec);
      break ;
                  delay(20sec);
                  count=0;
      break ;
else
     {LED=11111110;}
delay(2sec);
{LED=11111101;}
delay(2sec);
{LED=11111011;}
delay(2sec);
{LED=11110111;}
delay(2sec);
{LED=11101111;}
delay(2sec);
it have some some problem .
when press sw mcu inter count mode & hold there till delay time .if agen i press sw during hold time mcu not goes next counter mode . it goes when delay time complete there .
whats wrong with me .
Use switch as external Interrupt and which delay function you are using?
