BLDC motor speed calculation
krunal_299
Member level 4
Hi folks!
How can BLDC motor speed can be calculated from Hall sensor output?
Regards!
bldc motor speed calculation
measure the time between two transitions: ttr
it's the time it takes to go 60 electrical degrees (or 1/6 electrical period)
electrical frequency = (1/6) / ttr
multiply by 2xpi to get rd/s
multiply by number of pole pairs (P) to get mechanical speed
multiply electrical frequency by 60xP to get RPM
what determines the speed of a bldc motor
Hi again!
please correct me for folllwing example if it is wrong:
For 4 pole motor,
If i got one of 3 hall sensor output with frequency of 125 Hz, then speed will be:
2 pulse = 1 mechanical revolution.
So, for 125 Hz (125 pulse per second), speed = (125/2) revolution per second.
Which will give (62.5 * 60) = 3750 RPM
Am i right?
Regards!
bldc motor calculations
If you have 125Hz on one hall sensor and a 4 pole motor, your result seems correct.
calculation of motor speed
OK.....If you have 125Hz on one hall sensor and a 4 pole motor, your result seems correct.
bldc motor poles
Thanks a lot!
If the system has to be closed loop then , does above method to decide the motor present speed is accurate?
Or what would be any other more accurate approach?
Regards!
design calculation for bldc motor
Yes, you could have closed loop speed control with such a feedback. Just make sure your controller bandwidth isn't too much in conflict with you minimum operating speed (your speed estimation isn't "refreshed" as often at low speeds).
