Hello friend, I want to calculate the power driven by the motor while running.
Used :
- 1kw 3phase bldc motor and bldc controller
Now I am driving the motor using controller. The motor is running good.
Calculate:
For example say motor is running at 1000rpm. Battery voltage is 48v and consuming 3amp(DC).
Now I have to calculate the output power in phase ,in order to check how much watts the motor is consuming.
In motor phase how to check the AC current and voltage using dso. Because the multi meter will read for 50/60hz as AC.
