black box implemenation from system generator matlab
prashanthi999
Member level 1
black box in system generator
hello guys , i need some help in how to use a black box in system generator in matlab???
i have created a counter program in vhdl, i have called that counter.vhd in black box, i have given clk,rst input to it using gateway in, but im nt getting any counter values from the black box kindly help me !!!!
here is my blackbox.slx image
my clk,rst are std_logic, so i have used boolean for representing reset from gateway in, and clock as fix_1_0 from gateway in. kindly help me???
vGoodtimes
Re: black box in system generator
does the module have an active low reset?
prashanthi999
Member level 1
no normal reset only , that means when the reset is '0', the model counts upto 15, since im using a 4 bit counter.
im not able to implement a small "and" gate using black box!!!, i have manually set my and1.config file output(c) to "bool", added my path 's:/.../and1.vhd', still some errors, how to sort this, whats the correct procedure?
prashanthi999
Member level 1
does any one know how to implement a black box block from the matlab system generator libraries, because i want to implement a "counter" mechanism from a black box block. i have been getting errors in config.m file? help!
