no there will be no kinda of communication.
bit error will arise when they get sync at bit time and read both bit at time.
for getting sync there should be same speed between the nodes.
As per my thinking when they read bit at perticular time at time but if speed is different then also no node will detect for causing error but node which is transmitting will cause the error of ack bcoz he will not get any kinda acknowledge from other node.
when crc error will generate??
hi, crc error is generated if the TEC not equals to REC .TEC-TRANSMIT ERROR COUNTER REC-RECIEVE ERROR COUNTER
CRC is calculated on both side.first transmitter send data with CRC in frame and receiver is match by calculating CRC at their end. if not matched then CRC error is genrated.
According to the calculation of transmitting node ,the receiving node will check wheather the crc calculation will match or not match.
If not match then crc error will generated.
