[General] bit timing calculations for UART
Joyhtidas
Member level 4
Bangalore, India
Am using UART for an applications, the Peripheral clock is 32Mhz and the
Baudrate is 800000bps.
My doubt is- how to calculate 1 bit time of transfer.
I need to calculate for 256 bytes of data.
JD
hello,
Baudrate is 800 000bps.
it is not the baud rate of an UART ..
itcould be the FOSC for the MCU
I suppose you are using a PIC MCU familly with Q=32Mhz or maybe Q=8Mhz * PLL(') => 32MHz
choose your baud rate :
example 19200 bauds ?
and a classic RS232 data format 19200,8,N,1
1 start + 8 bits data +No Parity+ Stop = 10 moments
Freq= Bauds rate/10 => Hz
Periode T= 1/F => 0.052 mS or 52 µS for each bit
for 1 car => 10x52µS => 520 µS
for 256 cars .. 133mS
What MCU ?
Hardware UART or Software UART ?
FOSC value ?
Not completely impossible to operate an UART at 800 kBaud, but more likely that you confused some specifications.
