bit mask data value and bit mask position selection
sra13
Newbie level 5
Newbie level 5
hi all, i need the concept that how to select the bit mask values and bit mask position in the code compression block . the corresponding diagram is attached in this post. if possible can any one help me?
where is the diagram??...we need to see it to help u..
hi i already uploaded the compression using bitmask image. pls refer my yesterday's post. the same image again cannot upload. can you reply me if possible
in this diagram, how the bit mask position and bitmask value to becalculated?
i sent the diagram. can u help me
i do not know where you got the image from...however if you refer to the below link....it has been explained by the author..you need to understand it yourself as its one of the algorithms used by the author...i believe he has explained it in his ieee paper.
