bit-banged LCD driver
banh
Advanced Member level 1
The attached driving waveform is taken from Renesas 38024 MCU manual.
However, the MCU i'm using does not have LCD driver module.
so i think about generating the waveform using i/o ports.
however, the waveform has 3 levels (V1, V2, V3): how to achieve this?
has anyone done sth similar to this before?
See the
AN563 Using PIC16C5X Microcontrollers as LCD Drivers
at the microchip site.
I think that it is exactly what you want.
    banh
hi,
i also found another application note..
but i found that most application notes do not go about explaining generating the waveform, especially the COMmon backplane's waveforms which have 3 levels of voltage.
any idea to generate the waveform for COM pins?
