Bipolar- based Distributed Amplifier
Leron
Member level 1
Member level 1
Hi Guys!
I am in big trouble with the design of a Distributed Amplifier using bipolar transistors (I know.. with Mesfet is much easier). Do someone of you have experience (maybe a .prj for ADS ;-) ) or some good reference?
Thank you
Leron
flatulent
Advanced Member level 6
Middle Earth
Major problem area
I suspect that the major problem will be the real part of the input impedance of the BJT being low in value. I suggest that making the input artificial transmission line impedance much lower than the BJT input impedance will make the problem better. That is making the C larger and the L smaller.
