binary to hex file using keil
Hassan Gazal
Junior Member level 3
i have keil and bin2hex but i can't use it to convert bin file to hex file
can any one please tell me about the steps
Im using Keil 4 uVision for Arm, to make HEX file, and if that's what you want to do, the step in this case is:
Menu Project
Options for Target "TargetX"... or ALT + F7...
In tab Output, mark the option Create HEX File.
Thanks my friend but this is not what i need , i will till you about the situation
i have a 89xxx usb programmer but you can only read the chip and save file as . bin not .hex , so that i need to convert .bin to .hex
so if there is a possible way to do that
Copy the hex file to folder which contains hex2bin.exe
If you placed hex2bin.exe in C:\hex2bin folder then
Open CMD window and go to C:\hex2bin >
type
hex2bin.exe filename.hex to filename.bin [press enter]
filename should be replaced by yout hexs filename.
Thanks for your Help (jayanth.devarayanadurga , nagkiller)
but do you have any way to convert Hex File to Asm language using Keil or something else
