-- restoring.vhd
-- Implements a sequential version of restoring division algorithm
-- section 3.2 Loop-unrolling and digit-serial processing
-- x = xn-1 xn-2 ... x0: natural
-- y = yn-1 yn-2 ... y0: natural
-- condition: x < y
-- quotient q = 0.q1 ... qp: non-negative fractional
-- remainder r = rn-1 rn-2 ... r0: natural
-- x = (0.q1 q2 ... qp)·y + (r/y)·2-p with r < y
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY restoring IS
GENERIC(n: NATURAL:=8; p: NATURAL:= 6);
PORT(
x, y: IN STD_LOGIC_VECTOR(n-1 DOWNTO 0);
clk, reset, start:IN STD_LOGIC;
quotient: OUT STD_LOGIC_VECTOR(1 TO p);
remainder: OUT STD_LOGIC_VECTOR(n-1 DOWNTO 0);
done: OUT STD_LOGIC
END restoring;
ARCHITECTURE circuit OF restoring IS
SIGNAL r, next_r: STD_LOGIC_VECTOR(n-1 DOWNTO 0);
SIGNAL long_y, two_r, dif: STD_LOGIC_VECTOR(n DOWNTO 0);
SIGNAL load, update: STD_LOGIC;
SIGNAL q: STD_LOGIC_VECTOR(1 TO p);
SUBTYPE index IS NATURAL RANGE 0 TO p-1;
SIGNAL count: index;
TYPE state IS RANGE 0 TO 3;
SIGNAL current_state: state;
BEGIN
long_y <= '0'&y;
two_r <= r&'0';
dif <= two_r - long_y;
WITH dif(n) SELECT next_r <= dif(n-1 DOWNTO 0) WHEN '0', two_r(n-1 DOWNTO 0) WHEN OTHERS;
remainder_register: PROCESS(clk)
BEGIN
IF clk'EVENT AND clk = '1' THEN
IF load = '1' THEN r <= x;
ELSIF update = '1' THEN r <= next_r;
END IF;
END IF;
END PROCESS;
remainder <= r;
quotient_register: PROCESS(clk)
BEGIN
IF load = '1' THEN q <= (others => '0');
ELSIF update = '1' THEN q <= q(2 TO p)&NOT(dif(n));
END IF;
END IF;
END PROCESS;
quotient <= q;
counter: PROCESS(clk)
BEGIN
IF clk'EVENT and clk = '1' THEN
IF load = '1' THEN count <= 0;
ELSIF update = '1' THEN count <= (count+1) MOD p;
END IF;
END IF;
END PROCESS;
next_state: PROCESS(clk)
BEGIN
IF reset = '1' THEN current_state <= 0;
ELSIF clk'EVENT AND clk = '1' THEN
CASE current_state IS
WHEN 0 => IF start = '0' THEN current_state <= 1; END IF;
WHEN 1 => IF start = '1' THEN current_state <= 2; END IF;
WHEN 2 => current_state <= 3;
WHEN 3 => IF count = p-1 THEN current_state <= 0; END IF;
END CASE;
END IF;
END PROCESS;
output_function: PROCESS(clk, current_state)
BEGIN
WHEN 0 TO 1 => load <= '0'; update <= '0'; done <= '1';
WHEN 2 => load <= '1'; update <= '0'; done <= '0';
WHEN 3 => load <= '0'; update <= '1'; done <= '0';
END CASE;
END PROCESS;
END circuit;
