abdul991
Junior Member level 1
Hello, i'm new to the 1768-H M3 microcontroller form NGX. I have a sample code which is working fine and has given no errors or warnings. this is the Build output result:
Build target 'FLASH'
assembling startup_LPC17xx.s...
compiling system_LPC17xx.c...
compiling GPIO.c...
linking...
Program Size: Code=728 RO-data=236 RW-data=4 ZI-data=516
FromELF: creating hex file...
User command #1: fromelf --bin ".\Flash 0x2000\GPIO.axf" --output ".\Flash 0x2000\GPIO.bin"
".\FLASH\GPIO.axf" - 0 Error(s), 0 Warning(s).
i've done settings in the Kiel4 which includes setting IROM1 area(0x2000) as well as Run#1 from elf--instruction.
i get the .hex file successfully but i'm not getting the .bin file
compiling GPIO.c...
linking...
