Category | Description | Unit Price (USD) |
Cement Resistor | 5 Watt 0.1 Ohm | 1.00 |
Cement Resistor | 5 Watt 0.5 Ohm | 1.00 |
Cement Resistor | 5 Watt 1 Ohm | 1.00 |
Cement Resistor | 5 Watt 8K2 Ohm | 1.00 |
Power Resistor | 50 Watt 0.5 Ohm Aluminum Housed Wirewound | 7.50 |
MOSFET | RFP50N06 N-Channel MOSFET, 50 A, 60 V MegaFET, 3-Pin TO-220AB ON Semiconductor | 1.00 |
IC | Sn76604 DIP-14 BIDIRECTIONAL SERVO-AMP PULSE WIDTH | 1.00 |
IC | NE556 Dual Timer DIP-14 | 0.40 |
Relay | RAL9W-K TAKAMISAWA Power Relay 9V | 1.50 |
Relay | RA9W-K TAKAMISAWA Power Relay 9V SPDT relay | 1.50 |
Relay | RA12W-K TAKAMISAWA POWER CUBE RELAY 8-PIN 0.013A (Coil), 12VDC (Coil) | 1.50 |
Relay | TAKAMISAWA Power Relay 9V SPDT relay | 1.50 |
Relay | TAKAMISAWA SZ-12W micro relay | 2.00 |
Relay | KAM LING KU1T-B 5V relay SPDT RES. Load 5A, 110VAC or 24 VDC, Coil DC 5V | 1.50 |
Relay | OMRON SPDT 9V Relay G5L-114P-PS | 1.50 |
Relay | OMRON SPDT 9V Relay G2E-184P-M-US | 1.50 |
Relay | Matsushita DS2Y-S-DC9V relay | 1.50 |
Relay | FUJITSU 244N-D012/02CS 2A, 12V | 1.50 |
Reed Switch | OEG OMR-H 500 ohm reed relay switch SPST | 0.50 |
Mini Meter | 5K Ohm /V Mini Meter | 0.60 |
Condenser Mic | HOSIDEN Electret Condenser Mic ~9.5mm (diameter) x 6.5mm (height) | 0.60 |
Condenser Mic | 博捷 Condenser Mic ~6mm (diameter) x 3mm (height) | 0.30 |
Condenser Mic | Condenser Mic ~6mm (diameter) x 3mm (height) | 0.30 |
Condenser Mic | HOSIDEN Electret Condenser Mic ~10mm (diameter) x 5mm (height) KUC3723-040245 | 0.60 |
Condenser Mic | Condenser Mic ~10mm (diameter) x 7mm (height) | 0.30 |
Condenser Mic | Condenser Mic ~9.7mm (diameter) x 4.5mm (height) | 0.30 |
Power Socket | NICOON Screw Mount Power Socket 250V 6A | 1.00 |
DIN Plug | 5p DIN plug plastic 180° (5 Pin) | 2.00 |
Crystal Socket | Radio Scanner Crystal Sockets for HC-25/U HC-49U HK-49/T HC-50/U | 0.50 |
Fuse Holder | Fuse Holder Case for 5x20mm Glass Tube Fuses 10A | 0.60 |
Transistor | NEC JE9018 NPN Transistor for RF TO-92 | 0.40 |
Transistor | HITACHI 9015 PNP Transistor TO-92 | 0.40 |
Transistor | 2SK1491 NEC Transistor TO-3P | 4.00 |
Transistor | BF410C Transistor TO-92 | 2.00 |
Transistor | MJE521 Motorola NPN Transistor | 1.50 |
Transistor | 2SC4242 NPN Transistor TO-220 | 3.00 |
Transistor | NEC 2SB772 PNP Transistor TO-126 | 0.15 |
Bridge Rectifier | W10 Bridge Rectifier 5A 1000V | 0.30 |
Bridge Rectifier | Bridge Rectifier KBL06 | 0.60 |
Bridge Rectifier | Bridge Rectifier KBL406 | 0.60 |
Bridge Rectifier | KBPC5010 Bridge Rectifier 50A 1000V | 2.00 |
