Biasing transistors VS lowering the voltage on the transisto
walters
Advanced Member level 2
Whats the difference when you Baised linear operation a transistor but turn down the voltage is starts to distort or break down making it unbiased?
What is this called when your power supply voltage is not biasing the transistor right? because the voltage is so low?
What does it do to the transistor when the voltage is so so low? and what is this called when u do this to a transistor?
when u are designing the biasing circuit, u know or assume the supply voltage right? then whats the point in later reducing the supply? how will the design hold true then?
Re: Biasing transistors VS lowering the voltage on the trans
cause im altering the design or transistors by changing the overall voltage to them
