walters
Advanced Member level 2
transistor baising
Why do you have to set Baising for a Tube or transistors?
What is the Operating Stage for a Tube?
What is the Operating State for a transistor?
How do i Bais a Tube?
How do i bais a tranistor?
I see Trim pots in preamps and power amps for tubes or transistors im really
scare to move these trim pots because most Tube preamps and power amps
are 300Volts and up and if i move the BIASING trim pot it can "over bias" the power tubes or "under bias" them what voltage is a good start so should i hook the oscilloscope up to a power amp what should i look for in BAISING a power amp?
How do i Bais a Power amp?
How do i Hook up a Oscilloscope up a the output of a power amp ? and what should the Oscilloscope display is the power amp is Baised ?
