biasing of npn photo transistor
Akhil Mohan
Member level 2
Member level 2
For my mini project I have purchased a npn photo transistor (l14g2). Can you tell me how can i give a proper biasing for that.
Previously I was using a photo diode as detector and its output is not pretty good, so i am trying with photo transistor
Thanks in advance :)
The mentioned link is not opening, I have gone through the data sheet of photo transistor, but am not clear about the biasing levels.
In my photo diode case, I was getting an output but am not satisfied with that one.
Can you help me to design the biasing and detector circuit for an IR input?
i think the last link opens the pdf of fiarchild company....
it says Finally, the phototransistor should be biased (voltage applied to VCC ) with 5 Volts. The maximum bias is 16 V, however the performance of the component doesn’t change with a greater bias except when the phototransistor is used as a switch -- the high level output will equal the higher setting.
I read from the web the photo transistor base leg can be left as not connected. So I am with that.
I will let you know the results later
