[SOLVED] Bias tee and resistor decade box - Suggestion
palmeiras
Full Member level 6
Full Member level 6
South America
Hello Guys,
Please, I need to buy a Bias tee to bias a source follower (Connector 1: RF + DC, Connector 2: DC (input) and Connector 3: RF (output - connect it in the spectrum analyzer).
The RF signal is 2.5 GHz.
Do you have a suggestion of a good brand and where to buy it?
I also need a variable load (like resistor decade box with BNC connection), where the resistance varies from 50 to 50 kohm. Do you have a suggestion?
Thank you so much,
have not used a decade boxy in ... decades. They have so much wire length inside of them that they are fairly useless in modern electronics, even a simple op amp will oscillate with one in the circuit.
easy way to do your own decade box
resistance : **broken link removed**
capacitors : **broken link removed**
hope this helps.
