best software to design rf pcb
mvdeepaknair
Member level 1
ads simulation software student version
can anyone suggest me a good software by which i can draw the printed circuit boards for antenna, microstrips, and other rf components. if anyone can suggest a software that can transfer the design of hfss to any pcb software then it will be a great help me.
thanks ....
Abhishekabs
Advanced Member level 3
India
best rf simulation software
Hi
U can use software called PADS.
https://www.mentor.com/products/pcb/pads/
free student version is available.
If u r using software like HFSS or ADS or any rf simulation software.
they provide facility to convert your designed layout in it gerber file.
so u can use that file for PCB making.
for antenna u can use cad software.
Abhishekabs
ghas
Newbie level 2
best software for pcb
try electronic workbench i think it'as the best for designing circuit board or antennas
palesha
Full Member level 2
rf pcb design softwrares for free
If ur going to make pcb upto 2 layers, then sprint layout 5 is the best. It is very user friendly & very cheap also.
springf2000
Full Member level 6
top pcb software
the protel is easy to use, it can satisfy your application
livemath
Member level 2
Major application software uses the dxf standard. What you need to do is to export from and import to...
Goodluck...
Sadegh.j
Hey
This more a question than an answer, can you use the layout capabilities in ADS?
livemath
Member level 2
Yes we can, but we shouldn't expect ADS to perform like Mentor Graphics or Altium does. ADS layout is more on RF.
I've attached the example layout, we can also output the file on dxf , gerber and other format.
Goodluck...
khouly
Advanced Member level 5
EGYPT
yeah ADS layout editor is intended for RF layout , which is usually a samll part of the board , then this layout is exported to one of the PCB design tools , to complete the all circuit
khouly
Sadegh.j
thanks,
So after you finish the schematic, you do the layout and then you still have to use another software to finish the layout, am I right?
Abhishekabs
India
According to my knowledge.
When you create layout, then you make Gerber file from layout itself.
no different software is used, ADS do al things.
I am attaching one file which will clear all your doubts.
Still face any problem tell me
Abhishekabs
BigBoss
Turkey
In my opinion...
The best software is Cadence SPB I have ever used for RF-Microwave and for other applications in terms of accuracy,scalability,flexibility,compatibility.It's also very user friendly and last version is direct linked to ADS to simulate the PCBs.
But more accuracy is required for mmW applications (beyond 20GHz) AutoCAD based softwares are quite popular.
But in this case, Cadence IC layout editor is also used for this purpose..
There are many objectives to be considered..
drabos
Full Member level 6
ADS, Microwave Office for the RF/MW part. For me the difference MW Office looks better :), but I guess ADS has more accurent simulation tools.
Cadence has advanages when you want big layout with maybe other analog parts, digital part etc.
Mainly a microwave pcb is very small, contains just some active devices, MMICs and some microstrip line, bypass capacitor, a regulator IC, and some SMA connector.
Added after 4 minutes:
and I have never used more layers for microwave design, just one layer and a full ground layer and a huge amount of vias in the critical parts.
khouly
EGYPT
yeah , i agree with drabos
i have used ADS in Microwave design , the microwave part is small , with just one layer
ADS showed a great accuracy and the measurent results are very close to simulations
khouly
mImoto
Full Member level 4
I would use a Microwave Soft for calculation of trace widths and a PCB Software for the PCB Design.
khouly
EGYPT
Ansoft designer is good as well , but it is still new ,
i perfer ADS , then MWO
khouly
Abhishekabs
India
Free version or say Student version of Ansoft designer is available so any one can use it.
Good facilities are provided in free version also.
ADS & MWO are too Costly for student to purchase.
sadid
Protel DXP is the best i think
but how much does it cost?
