lepass7
Newbie level 3
- Joined
- Jul 20, 2014
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 35
Hello,
As a part of my project I would like to be able to know the temperature inside a water tank. This project has some limitations:
1. Distance (sensor will be 2-15 meters away from the controller)
2. Sensor wire will have to pass next to power cable (220-240Vac 50/60Hz).
3. Sensor will be immerse into media (water)
4. Temperature range 0-100 Celsius (max)
5. Cheap solution.
6. Accuracy 1-2 Celsius is acceptable.
7. Microcontroller (probably PIC or arduino)
Please have a look the attached drawing (yes I know I am not an artist).
I would love to hear your suggestions, regarding the type of sensor I should use (pt100, lm35, thermocouple ... etc).
Thank you,
5. Cheap solution.
Thank you,
