Best PCB Cleaning solution?
cameo_2007
Advanced Member level 3
12°58' N77°38'E
pcb cleaning solution
Hi
I have a master board for a microcomputer which has got a processor,Ram,Rom etc and other peripheral components assembled here.
It was assembled here in our in-house R&D.But the board does not look stable.say,sometimes the display hungs etc..I doubt whether teh board is not cleaned properly.Any chances of that?
If so which is the best pcb cleaing soulution to be used for such kind of sensitive boards?
Any clues??
Regards,
circuit board cleaning solution
I am using isopropyl alcohol (IPA) for PCB cleaning, you may try it.
Atul
cleaning circuit boards with alcohol
No dear..I have been using the same thing.And i think its not suited for such very sensitive boards which is completely built with tiny smd components.I gives me drylook at some places and ttally I want a very good solution for that.
Rgards,
clean circuit board alcohol
haven't you just try cleaning of the dusts or sumting with a canned air? it works for me though..
cleaning pcb alcohol
You must clean with Iso prophyl alchol and then you must wipe the board again with Tri chloro ethylene this will result in clean board do not use more tri chloro ethylene
ramesh
alcohol to clean pcb
as for me, I'm using non-combusting oil (non-flammable) for cleaning PCBs, alocohol may danage the coating of the board (which protects the copper traces from moisture from the environment)
alcohol for cleaning pcb
You may use Iso Propyl alcohol (IPA) for cleaning the PCB. Bur make sure wait till it evapoartes
clean pcb alcohol
Iso Propyl alcohol
Universally used for cleaning PCB. It is also used to clean LP records to present day cd & DVD's.
pcb cleaning alcohol
use isopropyl alcohol, that is really nice for cleaning, first use with brush, clean that ,
next use IP with cotton cloth, it will clearly remove every dust, fingerprints etc... just try this
pcb cleaning with alcohol
I'm working in aerospatial circuits for years, we always use IPA (isopropylic alcohol) with a small but hard paint brush to remove flux and other stuff from the PCB. Then, we use compressed air to dry and blow away dirts.
