Best numerical tehniques for simulating UWB antennas?
sherb
Junior Member level 1
hello,
what are the best numerical tehniques for simulating UWB antennas?
regards,
Sherb
adel_48
Full Member level 6
UWB antennas simulation
I think for large structures you need FDTD, for smaller ones MoM may be employed, for very small strucutres FEM can also be used
    sherb
IICCEE
Full Member level 3
China
you may also use the MOM or FEM method combine the AWE method.
aaron412
Member level 3
Re: UWB antennas simulation
Since you're simulating UWB antenna you need results for a large number of frecuencies so you should use a time domain method like FDTD which generates results for many frecuencies at the same time.
xxgcatz
Member level 2
i think cst mws is suitable fo the simulation of uwb antenna. its transient analysis is very good !
sherb
sorry IICCEE what do you mean by the AWE method, I haven't heard of it before?
Wiley
Member level 4
AWE is the Asymptotic Waveform Evaluation method. It expands the matrix elements in a Taylor series with respect to frequency to evaluate the derivative of the Z matrix with respect frequency. The derivatives you have the greater the bandwith of your approximation.
Almost every frequency domain comercial solver uses some variation of this method to compute a frequency sweep. For instance ALPS is essentialy the same but a Pade expansion instead of a Taylor series. Computing every frequency point is very wasteful.
adel_48
Full Member level 6
thank you very much wiley for your brief description. Actually I became very interested, is there some place where I can get more details?
Wiley
Member level 4
ryfnjust
Member level 1
I think cst microwave studio which is based on finite integration method is better that xfdtd. The former can mesh the structure in nonuniform way which can save a lot of computer resource and time with the same accuracy with that using xfdtd.
xcyyx
Junior Member level 2
Why not HFSS or IE3D
