fernandomierhicks
Hi:
I have a setup were I run a electromagnet with a PWM signal using 20 volts, usually at low dutycyles < 20%. PWM frequency in the low kHz range.
Around this electromagnet I have various sensors, cirucits etc.All of this (electromagnet and circuits) is inside a metal chamber (faraday Cage). I need to run some signals outside this chamber, analogue and digital.
The power supplies for the Electromagnet and the other circuitry are ground-isolated.
I want to reduce the noise that the Electromagnet is going to produce on my signals both because of the pulsing and the EM interference.
I was thinking of using coaxial cables for all my signals, using a star scheme once the wires are inside the chamber, so I will have a dedicated ground wire.
Should I also use coaxial cable for the electromagnet leads? Should I ground the shield on this wire to my general "signal ground"?
Should I ground both ends of my signal wires shield?, lets say to the frame?
Any other suggestion recommendation is appreciated, wire types are flexible.
Thanks
Fernando
Thanks
Fernando
