I am trying to understand the behaviour of the LM2577 regulator.
I require to generate 9 VDC (100 mA max current) output. The input voltage will start from 5 VDC and go upto 30 VDC, the output voltage and current must be maintained.
I have calculated the R1 and R2 resistance values. However I am not clear what happens when input voltage is equal or more than 9 VDC, does the regulator step down the voltage automatically ? Assume load current is constant at 100 mA.
Also is there any other chip similar to the LM2577 but in 8 pin DIP form ?
Thanks
a
