When I connected an astable timer circuit, I followed this scheme:
But now I see in the official datasheet for LM555 used above:
http://www.ti.com/lit/ds/symlink/lm555.pdf (figure 4)
and for NE555 which I use:
http://www.datasheetcatalog.org/datasheet2/c/0hex3d1gxjejda7ur3y2toipkzfy.pdf (fig 12)
that they pull the OUT pin high with 1kΩ in the datasheets. In my circuit, I just leave my output floating directly on the base of a transistor (works fine, thus far). Isn't it pulled high or low internally already? Must I do this externally?
And in general:
1) How can I know when a pin of an IC is internally "pulled" already, and when I need to take care of it myself? I'd like to learn how to read such information out of datasheets such as those I linked to above. Circuit figures 12 and 4 in the respective datasheet, seem to give a recommendation in drawing, but is it actually spelled out anywhere?
2) Should I pull high OR low? Is the pin OUT of a 555 switching between pulse high and floating, or is it switching between pulse low and floating? If it's never floating, then why do they pull it high in the datasheet?
3) And by how many ohm should I pull? I suppose that I should aim for a certain ampere given my Vcc level. Is 1-5 mA generally a good number (which means a handful of kΩ), or how can one read out of datasheets what's a good choice for a particular IC? Wouldn't I save battery if I increase the value of the pulling resistors?
(In monostable mode, the circuit of my first link does pull the OUT pin high, but by 100 times more ohm than in the second datasheet, 100kΩ instead of 1kΩ, with 5V Vcc then causing a tiny 50µA current during low pulses, if I understand it correctly. This is maybe not an exact science, but I'd like to at least find the ballpark on the map.)
