begin end block and Non-blocking Statements
vickyuet
Member level 2
pakistan
Question 1:
statements in verilog are executed in parallel but my question is What if we put them inside a
procedural block?
Begin
Statement 1;
Statement 2;
end
Now tell me in which order these are executed?both parallel or statement 1 then 2?
Question2:
If statements inside begin end runs sequentially then why non-blocking statements(<=) runs in parallel,though they are in begin end block
REGARDS,
FvM
Super Moderator
Staff member
Bochum, Germany
1. You already anticipated the answer in question 2, apparently you know it.
2. The statements don't run in parallel. In the below sequence, a is always set to 1. The point is, that the expression LHS (left hand side, or the result) won't be updated before the block ends. The difference only matters, if a is read inside the block.
begin
  a <= 0;
  a <= 1;
end
