Battery switch for RTC
kkdelabaca
Full Member level 2
batterypower for ds1337
Hello,
I am designing a clock with the RTC (DS1337) and have a small problem:
When the power is OFF, I need that the clock continues working.
Somebody recommends to me a commutator for the voltage of the RTC?
Regards!!
kkdelabaca
Have a look at the DS1210:
This IC unconditionally write protects when VCC is out-of-tolerance and automatically switches to battery when power-fail occurs or on power-off ..
Regards,
IanP
    kkdelabaca
Hello IanP,
I think that the DS1210 is a good solution. But if you put a pair of diodes 1N4148 is most cheaper. Exist some problem using this circuit?
|o----DIODE----o VCC (5v)
|o----DIODE----o batery (3v)
|------------------------------o Power of DS1337
