Batch file for ISE 9.2 not running
verylsi
Full Member level 2
Full Member level 2
Hello all,
I am trying to run generate bit file using batch mode.
The same project runs on another machine having XP service pack 2,
It was working for few day on windows 7 but suddenly it stopped running.
the terminal window pops up and closes immediately.
Any suggestions to fix this?
Open a command window. start->run->cmd
CD to the directory where the batch file is located and run it on the command windows command line.
You're getting an error, that's why it closes immediately.
Reactions: verylsi
    verylsi
Hi ads-ee,
Thanks, now the batch file is running and it the terminal is not disappearing. although
the following error is showing in the windows -
Could Not Find E:\work\CASHEL\TX_1_03_B17\TX_1_03_B17\FR_FL2_PRJ\ise_flow_results.txt
I dnt know ehy it could not find the above mentioned file , as the file is present in the mentioned directory.
Please help.
Thanks.
That's why you should always run batch files from a command window (so you can see the errors).
Is that file being called out from the batch file itself? As it looks like an output file, do you have permissions to write to the directory and make sure the file isn't read only.
If you have write permission to the directory/file, then try a relative path instead of the full path.
Regards
