Basic rules for planning the power routing of a design
kjtom
Newbie level 5
I am a newer for APR.
There is a technical and empirical step, badgering me.
How wide of power line? How many straps line needed?....
Are there some "basic rules for planning the power routing of design" ?
Could any predecessor give me guides or document? Thanks
About power routing?
not sure of APR. there is a document called "dtmf" from encounter, available in this forum. it gives a brief overview of how the power rings and stripes are used in a sample design. if u go through it, u might get a basic idea.
    kjtom
Generally, EM and IRdrop is considered in the power plan.
EM confine the max electricity on the metal and via, which you can find in your techonology library, .lef(Cadence), .tf(Synopsys).
IR drop confine the max voltage drop in the chip area, which you can find some clue in the cell timing library, .tlf (cadence) and .lib (synopsys). generally, the worst drop should be limited below 10%.
tools are available for analysis of the EM and IRdrop, and your job is simply draw a acceptable power network in regarding the above two factor.
however, it's not quite simple as it sounds.
have fun.
    kjtom
Re: About power routing?
In order size power strap width , there is a method given in site www.vlsi-technology.org , there will be paper on IR drop or just refer the pdf given( i have just grouped all html pages of that paper and converted into pdf).
pitch , width and group spacing is important mesh design.
just read that pdf and incase of any query do get back to me
regards
navien
    kjtom
It is very useful. Thanks for your sharing.
navien,
great compilation, it usefull
__sree
