Basic question...confusing me....
Guru59
Full Member level 4
Can any one explain the functionality of "&&" operator....
for example:::
a = 1010
b = 0001
then what is the value of " a && b " .....
hey, its very simple.
single &, | represent bitwise operators. while double & ,| ( ie && , || ) represents logical operators.
o/p of logical operators is a single bit. i.e. 1 (if true, non-zero) or 0 (if false , zero).
In ur case both "a" and "b" are non zero, hence the o/p is TRUE (in digital terminology it is 1 )
Hope it helped u.
If the queston was a&b, then ans is 0000
it seems like logic operator,&& is AND .
so if a or b is zero,the ans is 0.
if both a and b are not zero ,the ans is 1.
The && operator is only 2-state. It is either 1 or 0 depending on the operands.
The & operator is 4-state. It can be 1, 0, X or Z depending on the operands.
&& is called a logical operator because both sides need to be 1 in order for the output to be 1. In all other cases, it is 0. So if you had a = 0010 and b = 0110,
a && b would give you 0 (or compile error depending on your synthesizer).
A better (and proper) way to use && would be:
(a == 0010 && b == 0110)
& is a bitwise operator because it takes the bitwise AND of both operands.
So, a & b would result in 0010.
hey is'nt && operator concantenation operator in vhdl and verilog...
a="1010";
b="0001";
then "a && b" must be "10100001"...
hope i'm right... correct me if i'm wrong...
concatenation in verilog is done is using braces {} with , seperating the objects to be concatenated. && is used for bitwise ANDing.
& operator is used for concatenation in vhdl:D:D:D:D
