[SOLVED] Basic OFDM MATLAB Code
vaah
Member level 3
Member level 3
US
i just wanted to start frm the main basic part for implementation of ofdm
i need a matlab code for it:shock:
Can any one PLEASE Help me with that please ... ! ?:?:
hello
with google a have this code :
% OFDM_signal.m
clear
N=8; b=2; M=2^b; Nos=16; NNos=N*Nos; T=1/NNos; time = [0:T:1-T];
%if b==1, Mod='BPSK'; mod_object = modem.pskmod('M',M); A=1;
% elseif b==2, Mod='QPSK'; mod_object = modem.pskmod('M',M); A=1;
% else Mod=[num2str(2^b) 'QAM']; mod_object = modem.qammod('M',M);
% Es=1; A=sqrt(3/2/(M-1)*Es);
%end
%[inI,inQ,Mod,Nsym] = mapper(b,N,'Y');
%msgint=randint(1,N,M); X=A*modulate(mod_object,msgint);
[X,Mod] = mapper(b,N); X(1)=0+j*0; % A block of 16 QPSK symbols with no DC-subcarrier
for i = 1:N
if i<=N/2, x = ifft([zeros(1,i-1) X(i) zeros(1,NNos-i+1)],NNos);
else x = ifft([zeros(1,NNos-N+i-1) X(i) zeros(1,N-i)],NNos);
end
xI(i,:) = real(x); xQ(i,:) = imag(x);
end
sum_xI = sum(xI); sum_xQ = sum(xQ);
figure(1), clf, subplot(311)
plot(time,xI,'k:','linewidth',1), hold on, plot(time,sum_xI,'b','linewidth',2)
title([Mod ', N=' num2str(N)]); ylabel('x_{I}(t)'); axis([0 1 min(sum_xI) max(sum_xI)]);
subplot(312)
plot(time,xQ,'k:','linewidth',1); hold on, plot(time,sum_xQ,'b','linewidth',2)
ylabel('x_{Q}(t)'); axis([0 1 min(sum_xQ) max(sum_xQ)]);
subplot(313), plot(time,abs(sum_xI+j*sum_xQ),'b','linewidth',2); hold on;
ylabel('|x(t)|'); xlabel('t');
clear('xI'), clear('xQ')
N=2^4; NNos=N*Nos; T=1/NNos; time=[0:T:1-T]; Nhist=1e3;
for k = 1:Nhist
for i = 1:N
if (i<= N/2) x = ifft([zeros(1,i-1) X(i) zeros(1,NNos-i+1)],NNos);
else x = ifft([zeros(1,NNos-N/2+i-N/2-1) X(i) zeros(1,N-i)],NNos);
end
end
HistI(NNos*(k-1)+1:NNos*k) = sum(xI); HistQ(NNos*(k-1)+1:NNos*k) = sum(xQ);
end
N_bin = 30;
figure(2), clf, subplot(311)
[xI_dist,bins] = hist(HistI,N_bin); bar(bins,xI_dist/sum(xI_dist),'k');
title([Mod ', N=' num2str(N)]); ylabel('pdf of x_{I}(t)');
subplot(312)
[xQ_dist,bins] = hist(HistQ,N_bin); bar(bins,xQ_dist/sum(xQ_dist),'k');
ylabel('pdf of x_{Q}(t)');
subplot(313)
[xabs_dist,bins] = hist(abs(HistI+j*HistI),N_bin); bar(bins,xabs_dist/sum(xabs_dist),'k');
ylabel('pdf of |x(t)|'); xlabel('x_{0}');
basic OFDM
RESSOURCE RECHERCHE GOOGLE
% OFDM_basic.m
clear all
NgType=1; % NgType=1/2 for cyclic prefix/zero padding
if NgType==1, nt='CP'; elseif NgType==2, nt='ZP'; end
Ch=0; % Ch=0/1 for AWGN/multipath channel
if Ch==0, chType='AWGN'; Target_neb=100; else chType='CH'; Target_neb=500; end
figure(Ch+1), clf
PowerdB=[0 -8 -17 -21 -25]; % Channel tap power profile 'dB'
Delay=[0 3 5 6 8]; % Channel delay 'sample'
Power=10.^(PowerdB/10); % Channel tap power profile 'linear scale'
Ntap=length(PowerdB); % Chanel tap number
Lch=Delay(end)+1; %Channel length
Nbps=4; M=2^Nbps; % Modulation order=2/4/6 for QPSK/16QAM/64QAM
Nfft=64; % FFT size
Ng=3; %Nfft/4; % Ng=0: Guard interval length
Ng=Nfft/4;
Nsym=Nfft+Ng; % Symbol duration
Nvc=Nfft/4; % Nvc=0: no virtual carrier
Nused=Nfft-Nvc;
EbN0=[0:5:20]; % EbN0
N_iter=1e5; % Number of iterations for each EbN0
Nframe=3; % Number of symbols per frame
sigPow=0; % Signal power initialization
file_name=['OFDM_BER_' chType '_' nt '_' 'GL' num2str(Ng) '.dat'];
fid=fopen(file_name, 'w+');
norms=[1 sqrt(2) 0 sqrt(10) 0 sqrt(42)]; % BPSK 4-QAM 16-QAM
for i=0:length(EbN0)
randn('state',0); rand('state',0); Ber2=ber(); % BER initialization
Neb=0; Ntb=0; % Initialize the number of error/total bits
for m=1:N_iter
% Tx______________________________________________________________
X= randint(1,Nused*Nframe,M); % bit: integer vector
Xmod= qammod(X,M,0,'gray')/norms(Nbps);
if NgType~=2, x_GI=zeros(1,Nframe*Nsym);
elseif NgType==2, x_GI= zeros(1,Nframe*Nsym+Ng);
% Extend an OFDM symbol by Ng zeros
end
kk1=[1:Nused/2]; kk2=[Nused/2+1:Nused]; kk3=1:Nfft; kk4=1:Nsym;
for k=1:Nframe
if Nvc~=0, X_shift= [0 Xmod(kk2) zeros(1,Nvc-1) Xmod(kk1)];
else X_shift= [Xmod(kk2) Xmod(kk1)];
end
x= ifft(X_shift);
x_GI(kk4)= guard_interval(Ng,Nfft,NgType,x);
kk1=kk1+Nused; kk2= kk2+Nused; kk3=kk3+Nfft; kk4=kk4+Nsym;
end
if Ch==0, y= x_GI; % No channel
else % Multipath fading channel
channel=(randn(1,Ntap)+j*randn(1,Ntap)).*sqrt(Power/2);
h=zeros(1,Lch); h(Delay+1)=channel; % cir: channel impulse response
y = conv(x_GI,h);
end
if i==0 % Only to measure the signal power for adding AWGN noise
y1=y(1:Nframe*Nsym); sigPow = sigPow + y1*y1';
continue;
end
% Add AWGN noise________________________________________________
snr = EbN0(i)+10*log10(Nbps*(Nused/Nfft)); % SNR vs. Eb/N0
noise_mag = sqrt((10.^(-snr/10))*sigPow/2);
y_GI = y + noise_mag*(randn(size(y))+j*randn(size(y)));
% Rx_____________________________________________________________
kk1=(NgType==2)*Ng+[1:Nsym]; kk2=1:Nfft;
kk3=1:Nused; kk4=Nused/2+Nvc+1:Nfft; kk5=(Nvc~=0)+[1:Nused/2];
if Ch==1
H= fft([h zeros(1,Nfft-Lch)]); % Channel frequency response
H_shift(kk3)= [H(kk4) H(kk5)];
end
for k=1:Nframe
Y(kk2)= fft(remove_GI(Ng,Nsym,NgType,y_GI(kk1)));
Y_shift=[Y(kk4) Y(kk5)];
if Ch==0, Xmod_r(kk3) = Y_shift;
else Xmod_r(kk3)= Y_shift./H_shift; % Equalizer - channel compensation
end
kk1=kk1+Nsym; kk2=kk2+Nfft; kk3=kk3+Nused; kk4=kk4+Nfft; kk5=kk5+Nfft;
end
X_r=qamdemod(Xmod_r*norms(Nbps),M,0,'gray');
Neb=Neb+sum(sum(de2bi(X_r,Nbps)~=de2bi(X,Nbps)));
Ntb=Ntb+Nused*Nframe*Nbps; %[Ber,Neb,Ntb]=ber(bit_Rx,bit,Nbps);
if Neb>Target_neb, break; end
end
if i==0
sigPow= sigPow/Nsym/Nframe/N_iter;
fprintf('Signal power= %11.3e\n', sigPow);
fprintf(fid,'%%Signal power= %11.3e\n%%EbN0[dB] BER\n', sigPow);
else
Ber = Neb/Ntb;
fprintf('EbN0=%3d[dB], BER=%4d/%8d =%11.3e\n', EbN0(i), Neb,Ntb,Ber)
fprintf(fid, '%d\t%11.3e\n', EbN0(i), Ber);
if Ber<1e-6, break; end
end
end
if (fid~=0), fclose(fid); end
disp('Simulation is finished');
plot_ber(file_name,Nbps);
