linkstatic
Junior Member level 1
What i wanted to ask is simple. If i am using a 16x2 LCD and using 4-bit Data ,not 8 -bit, is it necessary to ground the other 4 pins which are unused? If there is a 15 and 16 pin on the LCD do i need to use it too? what if i leave the D0-D3, pin 15 and pin 16 open without grounding them?
If my proteus successfully runs the LCD in the simulation is it 100% that the circuit will work in real world?
