Basic Definitions of Third Party Trafficker and Super regenerative Radio
ahmad_abdulghany
San Jose, California, USA
Hello all
I want to know some definition of terms if you can help:
- Third Party Trafficer
- Super regenerative Radio
Is the latter an FM Rx type??
Thanks alot in advance,
Ahmad,
Re: Basic Definitions
A regenerative radio receiver is unsurpassed in comparable simplicity, weak signal reception, inherent noise-limiting and agc action and, freedom from overloading and spurious responses. The regenerative radio receiver or, even super-regenerative radio receiver or, "regen" if you prefer, are basically oscillating detector receivers. They are simple detectors which may be used for cw or ssb when adjusted for oscillation or a-m phone when set just below point of oscillation. In contrast direct conversion receivers use a separate hetrodyne oscillator to produce a signal.
Is there a thing called FM regen Radio?? or it's only for AM reception??
What I mean, Is this **broken link removed** an FM or AM radio?? Please tell me..
Thanks,
Ahmad,
