Bandwidth requirement of Ultra Wideband Antenna
Vineeth m p
Junior Member level 1
Hi all,
The bandwidth allocated for ultra wide band radios is 3.1-10.6 GHz. My question is, is it necessary for an antenna in a device that operates within this band should be able to cover whole of this band?
Regards MP
hi there
well that would be up to the designer of the transmitter/receiver and its bandwidth requirements, then design a antenna to suit
there's no point in having an antenna that covers 7GHz if the equip only needs a couple of GHz
Dave
Hi there,
well, the antenna is considered to be UWB when it has minimum 25% of bandwidth within the range released by FCC
calculate it from here
BW = [f (higher) -f (lower)]/ f (centre)
f centre = [f (higher) +f (lower)]/2
hope this helps
