Bandgap design with 0.2V reference voltage
xibeizi
Junior Member level 3
can I design a bandgap of 0.2V?
or how can I get a 0.2V reference voltage with zero tempureture coefficient
Re: bandgap design
hi
here i have to attached ur request
bandgap design
You can first design a bandgap reference, 1.2V for example, and then by a voltage follower and a resistor divider, you can get what you want, here you should pay attention to the resistor divider you used, all the resistors should be the same type, then the temperature coefficient of the resistors can be eliminated.
hope it helps!
Re: bandgap design
Thanks. I have design a circuit with resistor divider the voltage, and output 0.2v with zero temperiture coefficient.
