SwordFish
Member level 4
I have a bandgap and I want to know how can I be sure that it is stable.
I know that the negative feedback must be "stronger" than positive feedback but how can I check this ?
I have 2 bode plots , one for positive loop and one for negative loop.
I have to subtract the dB values of the 2 plots to see if at all freq the delta is higher than zero ?
Is enough to have PM>70degree on the negative loop, or I have to check this also to the positive loop.
In my case the negative loop is at 30dB in negative loop, and at 5dB in positive loop (this are values at low freq).
I use IC5 /Spectre with STB.
The bandgap is classic with PNP and 1 opamp.
Thanks.
Thanks.
