hi
im looking for bandpass filter matlab code for EEG signal. im interested to have filter for taking out gamma (25 to 80 HZ) signal from EEG raw signal. but im became confuse of lots of program which is exist and i dono how to use.
may anybody help me.
tank u in advance for your helping hand.
is there any way to bring my raw signal to FDA tool.
I have 19 channel EEG raw signal and im going to filter it. how can I use FDA to filter whole of the 19 channels together or I should do it channel by channel.
If you haven't gotten it going yet, I can try to help
So no, you don't bring your signal into FDA tool. All FDAtool does is spit out coefficients. Just use the 'filter' command in matlab to process your actual data based on your designed coefficients.
There is probably some fancy math/matlab way to process all your data at once. I would probably just use a for loop with the 'filter' function.
