Avinash Akotkar
Member level 2
I am working on "inductor less" Balun LNA Single input - Differential ended amplifier on 130nm for 433MHz. Attached IEEE transaction paper for same
Balun-LNA Schematic:
Here is my question:
1. In testbench, i used VCVS to convert differential to single ended so that I can do S-Parameter analysis on Two ports
Output I got: NF:3dB, S21=16dB, S11=-10dB but S22 is -3dB which is strange, I tried tuning load resistor as results other parameters impacted but S22 remains intact
2. Now Instead of VCVS I used balun for rflib, here other parameters like S22. S11, NF comes fine but S21 comes in -3dB (very strange)
So with both VCVS and balun I am getting different results,
Can anyone please help correct setup for Balun-LNA (Single-Differential) Testbench setup, I am stuck with this problem, if any user guide for same also helpful
