Balun design for differential narrowband LNA
LakshmiJL
Junior Member level 2
can anyone tell me how to design a balun for a differential narrow band LNA. Please help me with design equations if any.
Thank you
Working of LC Balun in differential LNA
Hi , can anyone please explain the working of a LC balun.how it is integrated with the differential LNA ,and its operation in detail
Can anyone please explain the working of LC balun in differential LNA. How does it function as a balun.
Please explain with regards to balun mentioned in the below link.
thank you
Re: Working of LC Balun in differential LNA
There 2 sections known as High Pass and Low Pass section.
At the resonance frequency, the Phase is +270 degree ( 180 degree coming from transformer is included ) on High Pass section.Similarly, the Phase is -90 degree on Low Pass section at the resonance frequency.
When you combine these phases into one, you obatin 0 degree so the signals are "in-phase"
Thank you . Can you also explain, how does it produce a phase shift at high pass and low pass section.
Calculate their transfer function and plot Magnitude and Phase response..You will see them at the cut-off frequencies..
