I want to build a circuit to drive 6 fluorescent tubes, the tubes are 15W each.
I haven’t done this before so there are a couple of things I’m not sure about.
Is the ballast just an inductor and if so is the size of inductance needed related to the power of the tube
What is the ballast doing anyway?
I think its doing two things but I’m not sure so does this sound right to you?
The starter closes, a high current flows through the filaments to heat them.
The current is limited by the ballast.
The starter opens, a high voltage spike is produced by the inductor, this spike initiates the flow of current through the tube.
Once the tube is running, (I’m really really not sure here because I don’t know the inductance or how much current a running tube would attempt to draw)
Either the ballast is effectively negligible or the ballast is limiting the amount of current drawn by the tube.
Any advice is much appreciated
Many Thanks
