Backup a PIC16F870 in normal mode with baterry?
neuralc
Full Member level 4
Hi all,
If some one have some info about how to backup a PIC16F870 in normal mode (not powerup, not sleep) (consumption arround 2 mA).
With baterry or Super capacitor?
ThX
NeuralC
The way to power backup with a capacitor is connecting two diodes in this manner:
..............D1.....................D2
VCC ------>|------+-------->|--------|uC|
.........................gnd
If you use a Capacitor of 0,33F, and your circuit drains 2mA VCC=5V, it will still working about 5500 seconds (>1 hour).
D1, and D2 is best if they are schotkly diodes. 8O
OK,
But with 1000uF (2mA), in 2 sec the cap will be discharged
Other opinions?
ThX
NeuralC
......................D1.....................
VCC (5V) ------>|--------------+-----|uC|
...............Vbat (4.5V)....D2....|
.......................__|__+
........................___ ...... 1,5V battery cell
Use Schottky diodes
When VCC is on D1 conducts and no current runs from the battery because of the lower battery voltage (4,5V).
When VCC is off the voltage between D1 and D2 drops to 4,5V - Vf(D2), then the battery starts to conduct.
OK
But like that baterry will not be charged.
ThX
NeuralC
If you want to charge the battery when power (VCC) is on you can use this schematic:
Remember to use NiCd or NiMH cells. You have to make some minor modifications to use it with 5V. Use shottky diodes instead of 1N4007 if you want a lower voltage drop across the diodes.
You can connect 5,8V to the circuit then you got a 5V output if you use schottky diodes with 0.4V voltage drop. If you connect 4 NiCd cells you got 4*1.2V-Vf=4.8V-0.4V=4.4V in backup mode.
Description: https://www.electronic-circuits-diagrams.com/telephonesimages/telephonesckt10.shtml
OK
Will try it
ThX
NeuralC
