Register Log in
Back Annotate Problem from Layout to Capture
BasePointer
Full Member level 2
TURKEY
Hi to all,
I have just finished my design in Layout and back annotated it to capture by creating a swap file from layout after renaming components.
But I have a big problem now, all components in capture have wrong value! and part reference.
How can I solve this problem ?
Please help me.
10x
taring77
Full Member level 2
from what i have ever experience the problem might not be solvable.
i was use to be told not to back annotate. U might have to do the capture manually.
its more advisable to do the layout after capturing schematic.
perhaps u have to look at the design fr layout n label in schematic manually.
taring77
Uky
Member level 5
Swedish West Coast
You have to maintain sync by doing a backannotation before you make any changes to the schematic. Then, all component placements and net properties will be inside the schematic database.
After verifying the sync, modify your schematic and forward annotate.
Watch the ECO options carefully before doing this. There's a large number of options that will screw up your MAX file.
:sm19:
TomSpade
Sorry, you're more or less screwed after the damage is done with back annotation. The Swap file is the way to go though....
1. BACKUP everthing in Pads and Orcard before you re-annotate. (I still do this, even though the process is down pat.)
2. Use ECO mode in Pads to create the re-annotation file (.swp extension)
3. Strip out the header and footer information from the .swp file. While your in there, check a few re-annotations by hand for sanity's sake.
4. "Back Annotate..." should fold the changes in (without errors). Make sure you are consistent with running it over the "design" or "selection". In most cases, you'd use "design".
