AXI protocol outsatnding transaction
sun_ray
Advanced Member level 3
What are the difference between outstanding transaction and out of order transaction in AXI protocol?
outstanding transaction : when master initiates a transaction without waiting it to complete, it can issue next transaction.
ooo txn: the order transactions are sent and the order the responses were received is not same.
prioritizing the transaction and compelling them not in the order in which they have arrive is out of order ccompletion. in axi4 only read transaction can be completed out of order while in axi3 read and write instruction can be completed out of order.
and sending the subsequent transaction address on same channel while one transaction is proceeding is known as outstanding transaction
Thanks and Regards
Vir_1602
thanks vir_1602
could you please give me the reference which justifies your statement that in AXI4 only read instructions can be performed ooo(out-of-order).
thanks in adv.
A6.4 mentions that reads and writes with different IDs can be performed in any order. To a single ID they must be issued in the order they arrived.
I have a doubt, in AXI3 also, if all the masters have same ID (or single ID, or without ID), can't perform out of order transaction.
I think Multiple ID should be must for performing out of order transaction, both in AXI3 and AXI4.
Correct me if I am wrong.
excuse me Mr or Ms.
I cant share axi4 spec due to arm's norm. and I said "write traction completed in a order; not out of order" I mean for a master it should receive its transaction as in the order it has sent.
hi
this will depend upon interface; becuz interface adds extra bits in to id and in that way they can complete out of order
(for imbiche)
hi annasaikiran
U can download axi4 spec from arm infocenter.
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.faqs/ki1hk8p7dqPG1c.html
Thanks and Regards
Vir
vir_1602
Is it that then ooo transaction have ti include outstanding transaction to execute ooo transactions? This is because in ooo transaction also address for read and write need to be issued one after another although the corresponding transactions have not completed?
Regards
first write have to be completed .
n sun ray ur lasrtpost is not cleared to me
Thanks and Regards
Vir
