AWR Microwave Office and 2N2369A Spice Model
enrico
Member level 3
Dear all,
I am looking for a help in modelling the transistor 2N2369A throught its SPICE model found in the internet.
Basically I need to bias the transistor and see the behavior, but once importing it through Microwave Office (Project->Add netlist->Import netlist->Import file as PSPICE netlist files (*.CIR)) I noticed that the device available at subcircuit has 4 ports instead of expected 3 ports.
1) How can I countour this problem ? Is it possible to neglect it and force MWO to assume 3 ports instead ?
2) How to make sure the pins are not inverted (base, emmitter and collector) ?
Thank you.
Look at the fourth port..It should be "substrate", then you can connect this port to ground..
Reactions: enrico
    enrico
Hello enrico,
you are doing correctly in importing PSpice model...
1. Yes Possible to neglect the S node or force into 3 node BJT....
use GBJT3 or GBJT model from MWO Elements => Nonlinear => BJT
Both are same but only has additional S node which you can ground...
2. while importing PSpice click on No for Swaping nodes Warning
I tried with default Q2N2369 spice model & it is working fine...
I don't have the spice model for your requested 2N2369A device but I see the Key parameters: Is=1.0302E-15 Bf=93.9499 Tf=2.30788E-10
which you can set in GBJT3 mannually
See my simple MWO example attached on how to enter these parameters, & a typical IV Curve, S-parameter schematic setups for Q2N2369 spice file for your reference...
I hope this helps you ...
---manju---
  • Q2N2369_MWO.zip
Reactions: enrico
    enrico
Hi Manju !
You are the guy !!! Many thanks for everything !
Thank you also Bigboss !
I have it working.
Regards, Enrico.
