K Srinivas Pavan Kumar
Member level 3
Hi friends,
I am making use of AVR Evaluation board v3 and ATMega16A as IC, HEXA FILE has created, but while uploading the hex file it is showing me unknown device.
I tried on command prompt and given the command as
avrdude -p atmega16 -P com6 -c avr910 -v -U flash:w:led.hex
and it is showing in command prompt as follows
Can anybody solve this for me
and 1 more doubt is I am making use of atmega16a and I have selected the ic as atmega 16,whether it results in the uploading problem
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 avrdude -p atmega16 -P com6 -c avr910 -v -U flash:w:led.hex avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23 Copyright (c) 2000-2005 Brian Dean, [url]https://www.bdmicro.com/[/url] Copyright (c) 2007-2009 Joerg Wunsch System wide configuration file is "C:\WinAVR-20100110\bin\avrdude.conf" Using Port : com6 Using Programmer : avr910 avr910_devcode (avrdude.conf) : 0x74 Overriding Baud Rate : 19200 AVR Part : ATMEGA16 Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PA0 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 5200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail : Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW Max W ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- --- -- --------- eeprom 4 10 128 0 no 512 4 0 9000 90 00 0xff 0xff flash 33 6 128 0 yes 16384 128 128 4500 45 00 0xff 0xff lock 0 0 0 0 no 1 0 0 9000 90 00 0x00 0x00 lfuse 0 0 0 0 no 1 0 0 9000 90 00 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 9000 90 00 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00 calibration 0 0 0 0 no 4 0 0 0 0 0x00 0x00 Programmer Type : avr910 Description : Atmel Low Cost Serial Programmer Found programmer: Id = ""; type = ª Software Version = D. ; Hardware Version = ≡.∩ Programmer supports the following devices: Device code: 0xffffffff = (unknown) Device code: 0xffffffff = (unknown) Device code: 0xffffffff = (unknown) Device code: 0xffffffff = (unknown) Device code: 0xffffffff = (unknown)
