AVR Push button problem
nzkunal
Member level 2
push button avr
I am having some problem using a push button with an AT90S8535.
Basically the PB is connected to supply negative (GND) and the other end to an input pin PORTB.2. PORT B direction is input and initial value 1 (High)
When I prees the PB my code doesn;t seem to respond. I have checked the hardware connection i.e PORTB.2 does actually go to GND when PB is pressed, cant figure out why code doesn't respond. Is checking if PORTB.2 = 0 or 1 the right way to do it can anybody suggest some simple test code.
avr push button
Hi nzkunal,
I have no exprience with AVRs.
But Does PORTB have internal pullup resistor? If yes?
If No, you must connect a resistor (~ 4.7k) from the PORTB.2 pin to VCC
So the PB in open state the PORTB.2 is High , when you press the PB the PORTB.2 be LOW
So just read the input of the PORTB.2 to know if it's close or open.
Bye
avr push
Sorry, problem solved... before anyone points it out I just realised to read input ports in AVR u have to use PIN not PORT.
