[AVR] AVR ATmega8 hangs on some microswitch inputs
abdi110
Member level 3
My circuit takes some microswitches as inputs and based on them sends some data on the serial port. After few hours it hangs randomly.
I think it is because of the inputs since I connected the switches directly to the AVR port.
Should I use opto coupler for example to solve this issue? Could anyone please give a solution for this?
Optocoupler is not at all necessary. The standard way to do this is to set the AVR to pull up the pins connected to the micro-switches, and have the micro-switches complete the circuit to ground when closed (assuming they are normally open). It might be worth adding a capacitor (perhaps 10uF) between the AVR pins and ground to denounce them.
Thanks I pulled up the pins by internal pull ups. I will try the capacitors too.
My question is that if the microswitches cause hanging as I guess?
I also used 100nF capacitors before but I will try 10uF as you advised
the input pullup is about 150k (read datasheet). this gives a time constant of 150k x 100nF = 15ms. But only on rising edge.
The falling isfast, because there is no current limitng resistor. Maybe connect a 1k in sereies to ech switch.
For further discussion please attach a schematic.
Microswitches never cause a hanging microcontroller.
In many cases "hanging" is a software problem, or a PCB layout/wiring problem.
Like connection of RESET pin. Missing or wrong or wrongly wired supply capacitors. Missing ground plane.
Klaus
As KlausST said, the hanging is most likely a software problem so it would be good to see the code as well. At this point we don't even know whether you are polling the switches or using interrupts...
Thanks KlausST
Dear allsey87 I use polling
As i mentioned the software works properly for 2 or 3 hours but randomly with changing in microswitches it goes to hang situation therfore i think the software has no problem. I think as you mentioned the problem is because of bouncing so in order to solve that i should use a capacitor with an external pull up resistor.
Maybe it is better to say that in case of changing switches status there are some unwanted noise which enter the circuit and make the system to hang. Not the bounce of switch.
internal pullup, but external series resistor.
Therefore the RC at the inputs.
As said before: You need to read carefully the design considerations in the datasheet about RESET connection, VCC bypassing, clock connections and so on....
Klaus
It's hard to make any conclusions without seeing the code, but this sort of problem normally comes about because of a bad pointer or an overflowing buffer. You might also be crashing into your stack after awhile which could cause things to hang.
Anyway, further discussion is pointless until you post your code and tell us the exact AVR part that you are using.
Klaus
So you mean a series resistor for example 33 ohms in series with the AVR pin plus a capacitor between input and GND?
