[AVR] AVR ATMEGA32 simulations in Proteus ISIS
KFChoong
Hi Sir,
I am using proteus ISIS release 7.4 Sp3. And I am new to Proteus ISIS simulation software.
when placing the microcontroller - ATMEGA32 16PU, I encounter a problem that this component from Proteus library has lack of 2 pins, namely Vcc and GND.
without these two pins, I am not able to start coding and simulate the circuit. Please find attached circuit for practice I2C between 2 microcontroller.
is there anyway I can add this two pins into the component so that I can add in the hex code and start simulate the circuit ? Please help me out on this problem.
May thanks for helping me. :wink:
Best Regards,
KF
yes both comments are helpful.
you not need to worry about VCC and GND pins.
if you want to change try shahbaz.ele's method.
Hi Shahbaz, Jayanth, Kamranravian,
Many thanks for your help and advice. As you said, I will simulate this without worrying the power and ground pins.
I will consult you guys again when there is problem occurs after simulation.
Thank you.
Best Regards,
KF
